KmizeBH
#1 Posted : Friday, January 14, 2022 3:10:11 AM(UTC)
KmizeBH
I have been learning Vmix and so I have my GT file imported in, and I'm able to connect Vmix to Google Sheets. Once I connected it to the text I need to update on Google Sheets, the input goes completely black. Once I reload the input, it shows back with the information, but I need to figure out what's causing it to go black so I can prevent it from happening during live productions.
Thanks for any help!
meremultimedia
#2 Posted : Friday, January 14, 2022 5:26:05 AM(UTC)
meremultimedia
Italy
+1
#3 Posted: : Friday, January 14, 2022 5:33:53 AM(UTC)
KmizeBH
#4 Posted : Friday, January 14, 2022 5:35:40 AM(UTC)
KmizeBH
Originally Posted by: doggy Go to Quoted Post
https://www.vmix.com/knowledgebase/article.aspx/200/gt-inputs-show-up-as-blank
Unfortunately, that's not the issue. But I do appreciate the help. I think I fixed it but will update if so.
KmizeBH
#5 Posted : Friday, January 14, 2022 5:37:16 AM(UTC)
KmizeBH
Originally Posted by: meremultimedia Go to Quoted Post
+1
So I figured it out, well for my situation. Make sure that there is only one input of the gt title that you are using. Apparently there was a duplicate but it got messed up and it was effecting my actual input that I was using.
I hope you find your answer too!
thanks 1 user thanked KmizeBH for this useful post.
doggy on 1/14/2022(UTC)
