mcook75
#1 Posted : Wednesday, January 12, 2022 12:00:56 AM(UTC)
mcook75
Has anyone ever experienced their 10Gb network card crashing? I've had the same issue over 4 or 5 PC's and on different 2 switches!
This has only ever happened when running vMix, but they were bought for vMix, so don't really do much else!
What happens is, the system will be working fine for days, then the all network traffic stops on the card, it IP address stays the same. The only way to resolve this, is to disable the network card and re-enable it, then it all pops back up and works.
The fault doesn't trigger all at the same time, it could happened on one machine, but not effect another two on the same network.
Here's a rundown on the the key pieces of equipment;
- All machines have the Asus 10GB network card
- Netgear M4300 24 port switch (not running the latest firmware, but will be once the current show finishes!)
- Approximately 1GB bandwidth being used (8 vMix calls, 10-12 NDI links)
- Router is Peplink Max Transit Duo
- NDI links not currently running multicast
All the machines are different, but in general they're all 10th Gen i9/i7, RTX graphics cards, 32+Gb ram, windows 10, vMix 24 (updated as per the latest release).
If anyone has any insight into what may be the issue, it would be appreciated.
jtocci2
#2 Posted : Wednesday, January 12, 2022 8:09:58 AM(UTC)
jtocci2
Do you have the model number on our ASUS 10 GBE NIC?
A few ideas:
1) Have you tried running with the side of the case off? Curious is it's a heat issue.
2) Might also be worth trying different drivers -- if using the default from Microsoft, that could be your issue right there.
3) Does your switch have any sort of "storm control" -- with the number of NDI feeds bouncing around, that might trigger an over zealous managed switch.
4) Are you using the 4x SFP+ ports on that 24 port switch? DAC cables, or RJ45? I know the RJ45 SFP+ modules get toasty... that could be part of the problem.
5) Have you run an iperf test on your network setup to ensure that you're getting the 10GBE performance?
6) Following up on the previous item, have you tried other benchmarking tools (I know some folks like black magic design's speed test tool: https://www.diyphotograp...isk-speed-test-on-a-pc/)
7) Bottom line is, try to stress the system out piece by piece, isolating/replacing components until you find the failure. Trick with 10GBE networks, since it's unlikely that you have a replacement switch, and other components, but give it a shot.
8) worse case scenario, consider using a second 1 GBE NIC for a 2x 1 GBE network connectivity. I found that was a quick and easy fix when fully saturating a 1 GBE connection during tech checks before a major livestream.
mcook75
#3 Posted : Thursday, January 13, 2022 2:06:33 AM(UTC)
mcook75
thanks for getting back to me!
Asus XG-C100C
Yes it had no change
the one installed is the Asus driver
It does have storm control, Broadcast is on, but Multicast and Unicast are both off
we're not using the SFP+ ports, just the RJ45, with CAT6a cabling to the 10Gb PCs, the switch doesn't seem particularly hot
I have (just!) I was getting 8-9Gbs on all 10Gb PCs, so fairly happy with that
No not done that yet, although isn't that a disk test, not a network test?
I have tried different switches (same model), it does the same.
I haven't tried that, I could try adding the 1Gb connection to the run along side teh 10Gb one, but it's only running at 1Gb when fully loaded!
I feel like it's the Asus card that's failing, that's where i'm heading.
mcook75
#4 Posted : Wednesday, February 2, 2022 9:09:21 PM(UTC)
mcook75
I can confirm after changing the network card, everything seems a lot more stable!
This is the one I installed: 10Gb PCI-E Network Card X550-10G-1T
I'm unsure if there was a network config on either the card or switch that was causing the problem, but the new network card seems to have resolved the issue!
I created a load vmix file, that would crash the ASUS after 4 - 20 minutes, the new card hasn't crashed once! So I'm calling that a success!
