JxM
#1 Posted : Thursday, November 18, 2021 3:06:15 AM(UTC)
JxM
Hi there!
We currently own a PC with Decklink 8K and vMix installed. Great combo. We also have a laptop. And both systems have thunderbolt ports. We are thinking about buying an external thunderbolt enclosure with another Decklink 8K card installed to either expand the first system (to have 8 inputs/outputs available) or to have a very small, portable, yet powerful system with 4 SDI inputs.
I know it's possible to have an external enclosure with one or two Decklink 4K recorder cards installed and running, but I would prefer to see 4 inputs in one slot available. Would that work or would the bandwidth be too much for the Thunderbolt interface (and vMix) to handle? As far as I've read it should work on the paper as long as we get the right enclosure. Has anyone tried this?
Thanks!
sinc747
#2 Posted : Tuesday, November 23, 2021 8:34:51 AM(UTC)
sinc747
Thunderbolt 1, 2 or 3?
JxM
#3 Posted : Wednesday, November 24, 2021 4:44:14 AM(UTC)
JxM
3, of course.
AlbertoBCN
#4 Posted : Tuesday, December 28, 2021 5:48:21 AM(UTC)
AlbertoBCN
Views messages in topic : 8
Originally Posted by: JxM Go to Quoted Post
Hi there!
Thanks!
I will try the OWC Mercury Helios 3S Thunderbolt 3 with the 8k Pro. Once I test it I will let you know if it rocks.
thanks 1 user thanked AlbertoBCN for this useful post.
lainol on 1/10/2022(UTC)
rbusch
#5 Posted : Friday, January 7, 2022 10:13:21 AM(UTC)
rbusch
Singapore
Following this closely also....Please do share how it worked out, thanks!
voiceovercity
#6 Posted : Tuesday, June 17, 2025 11:57:49 AM(UTC)
voiceovercity
In case anyone is interested in this topic, be advised that the only enclosure I've come across that will work with the BlackMagic Decklink 8k Pro card is the Sonnet SE IIIe unit. Why? Because the card requires an additional power source be plugged in after it's installed in the case. Without that additional power, the card WILL NOT WORK. As of this email, the Sonnet SE IIIe is the only unit that offers the additional power.
Xavi137
#7 Posted : Tuesday, June 17, 2025 3:59:01 PM(UTC)
Xavi137
Just add that Thunderbolt 3 is 20GBPS up + 20GBPS down.
So a 2160 60p will be 12GBPS. You can only use one input and one output port on the Decklink 8k PRO.
KerryDP
#8 Posted : Wednesday, June 18, 2025 1:11:30 PM(UTC)
KerryDP
New Zealand
I'm looking at this model to house a Decklink Quad card: https://www.pbtech.co.nz...PCIe-Expansion-Chassis-w
Any thoughts on whether it will be compatible?
Kayo33
#9 Posted : Thursday, June 19, 2025 4:47:14 AM(UTC)
Kayo33
Was thanked: 16 time(s) in 12 post(s)
No problem normally
Just the DeckLink Quad HDMI card (pcie 3.0 x8) will be limited to PCIe 3.0 x4 (Thunderbolt 3 speed)
So 2 x HDMI inputs maximum
Maybe more if the signal is 4.2.2 or 4.2.0 8-bit
KerryDP
#10 Posted : Thursday, June 19, 2025 2:10:28 PM(UTC)
KerryDP
New Zealand
My intention is to capture 4x cameras via SDI, to either stream as 4x HD SRT feeds, or a single 2x2 UHD SRT stream (to be separated by Vmix at the receiving end, into 4x SDI outputs from a second Decklink Quad card.)
It is more expensive, but I'm thinking the Echo II DV Desktop is maybe better suited for my needs https://www.sonnetstore....roducts/echo-2dv-desktop which will feed a M2 Pro Mac Mini with Thunderbolt 4.
Kayo33
#11 Posted : Friday, June 20, 2025 3:10:48 AM(UTC)
Kayo33
Thunderbolt pcie enclosure
2 slots pcie :
https://www.pbtech.co.nz...C6fUptZxk6ejry2AYpR6FBRw
3 slots pcie :
https://www.rubbermonkey...ogbYcmk0p4GCY6CdZiYdcmC2
Only with pcie 2.0 x4 cards
bdm duo 2 for 4 inputs or 4 x outputs 1080p60
Otherwise, look into SDI to SRT/NDI encoders with SDI loop.
