Feature Requests
Fine Adjustment for Starting Point of Video / Audio replay
Joined: 3/30/2020(UTC) Posts: 17   Location: Leran Thanks: 14 times
Would it be possible to put the equivalent of a "thumbwheel" next to the slider control on the preview / output window to allow In and Out points to be be more accurately set ? The slider is very hard to adjust hyper-accurately with only a mouse control to move it, and the Mark In and Mark Out do not seem to be able to be set accurately. If we could have a fine adjustment control or the ability to set numerically the time of the In and Out points it would save a lot of time when cue-ing recordings. Many thanks Update: I think I am resurrecting an issue raised at https://forums.vmix.com/default.aspx?g=posts&t=10541which never seems to have been resolved. I have uncompressed video inputs I want to cue into a live broadcast and a thumbwheel would just make it easier. I can live with frame 'skips' if the compression algorithm forces these but from programs like Wondershare and Roxio I can cut a video anywhere I want because they both have a thumbwheel and/or the ability to enlarge the timescale.
Joined: 1/25/2019(UTC) Posts: 334  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
you can do this with shortcuts.  set.PNG (18kb) downloaded 3 time(s).-setposition -input preview -value -=40 for getting one frame back -value +=40 for getting one frame forward -value -=1000 for getting one second back -value +=1000 for getting one second forward Then add the shortcuts for Mark IN,Mark OUT, Clear IN, Clear OUT and everything is done. And if you have a Streamdeck panel, it works even better.  set2.PNG (45kb) downloaded 1 time(s).Keep in mind that with the different file formats, it is not always possible to change the position by 1 frame. With mp4 formats the steps possible are probably only +- 1 second. With vMix AVI oder ProRes you can jump every frame. This has to do with the encoding of the files (GOP).
 1 user thanked Peter1000 for this useful post.
Hi Peter
Thank you so very much for this quick and very informative reply.
I have a Launchpad Mini and have been trying to programme this for over a year but I had got the syntax slightly wrong for the -=x and +=x. You are right that I am limited to a 1 second skip, but 1 second is absolutely fine for what I need to do. But thank you for advice on how to achieve single frame advance.
I am also going to programme the shortcuts for the Mark In/Mark Out and Clears as you suggest.
Happy 2022 !
Feature Requests
