nikosman88
#1 Posted : Sunday, December 26, 2021 7:13:21 PM(UTC)
nikosman88
Greece
Hello. Is there any plans for vmix to add playout capabillities? So it will not be necessary to use other pc and playout software to work as playout server. The videolist/playlist that vmix has now it works but it is very poor compared to dedicated playout software programms. Some programms like vscheduler for vmix also work but have some bugs. Its different to have something embed in programm other than extra..
#2 Posted : Sunday, December 26, 2021 9:05:12 PM(UTC)
Lets leave vMix for what it is dedicated for and very good at: "Live Production & Streaming Software". Just My Opinion
So now your diamond has bugs ? LOL https://forums.vmix.com/...Scheduler-Fork#post98444
Although would not mind if it was able to get me my dinner in time ;-)
nikosman88
#3 Posted : Sunday, December 26, 2021 9:44:51 PM(UTC)
nikosman88
Greece
Even diamonds can have bugs.
Papo
#4 Posted : Monday, December 27, 2021 11:59:51 AM(UTC)
Papo
Peru
nikosman88, which should have vmix, could you expose it, vmix has a list entry, which would be like a standard player, it has the playlist ..., which you need, you could complement it with scripts for events at certain times, explain what you would add to the standard
translated from spanish to english by google
nikosman88
#5 Posted : Monday, December 27, 2021 8:36:08 PM(UTC)
nikosman88
Greece
Hi. My english are not good but i hope i can explain. I would like to have a better videolist system. For example when we add some clips,we can see the real time that clip starts. The most important is a feature like insert a clip in a specific position of the list. For example if we have a big playlist more than 2-3 hours with many clips its almost impossible to put a new clip in a specific position. Ok the trick here is to save the videolist as m3u file, open it with notepad and add the clip you want in the position you want, then save it and load again a new videolist.. This is not so practical..
Also if we would like to make a big videolist 10-12 hours or more, from one point and then, it is difficult to load a clip. You press add and even in a good pc, it takes some very annoying seconds until this clip will appear in the videolist. And if in this time you play for example another clip and this another clip comes to end,it freezes until the new clip in videolist load.
ginesromero
#6 Posted : Tuesday, December 28, 2021 3:12:14 AM(UTC)
ginesromero
Spain
Hi, in my opinion the best way to have a playout with vmix is to use Instaplayout. As you have been told vmix is a "Live Production & Streaming Software"
thanks 1 user thanked ginesromero for this useful post.
nikosman88 on 12/28/2021(UTC)
#7 Posted : Tuesday, December 28, 2021 3:22:12 AM(UTC)
Confusing with amber ? ;-)
nikosman88
#8 Posted : Tuesday, December 28, 2021 6:32:44 PM(UTC)
nikosman88
Greece
Yes i know this software. I tried the trial version but for some reason it crashes on my pc after some hour of playing. So for now i am using a combination videolist and playlist in to vmix. Smaller lists and put them in the playlist to autoplay. The problem here is that i have to watch not to load gpu mem too much.. I hope to buy a 3060 so i will use resizeable bar but for now it is too expensive for my budget
ginesromero
#9 Posted : Thursday, December 30, 2021 4:29:26 AM(UTC)
ginesromero
Spain
I imagine that you also know the option "vScheduler 24x7" of sitescape.
You can try to see if it works better for you. Although I personally think that the best lowcost playout is instaplayoput
nikosman88 on 12/30/2021(UTC)
msanthababu
#10 Posted : Wednesday, April 20, 2022 4:05:33 AM(UTC)
msanthababu
India
HI Friends,, I made Vmix Scheduler Using Task Scheduler,
pls Download and Try,,
comment me for more devolpment,
msanthababu
#11 Posted : Wednesday, April 20, 2022 4:06:41 AM(UTC)
msanthababu
India
try This
#12 Posted : Wednesday, April 20, 2022 4:15:57 AM(UTC)
Well played LOL ("development" btw and please especially in the video pay attention to the spelling !!)
Screenshot 2022-04-19 201307.jpg (35kb) downloaded 5 time(s).
msanthababu on 4/23/2022(UTC)
