Hardware Compatibility
11th Gen Intel Core i9 NUC Beast Canyon
I'm looking at using the Beast Canyon Nuc 11 with the 11th Gen Intel Core i9 & RTX 3060 (no ti.) Does anyone see a problem with my use outlined use below?
Nuc 11 Beast Canyon i9-11900KB RTX 3060 (no ti) 16GB 2.5GB Nic TWO Thunderbolt 4 ports Windows 10 Home
Sonnet Echo Express SE IIIe Thunderbolt 3 Edition PCIE Card Expansion System Blackmagic Design DeckLink Quad 2 8 sdi sources
The Video format will be 1920 x 1080 59i (mostly)
Live streaming - encoding will be from a dedicated computer.
Max use: 6-8 cameras 2-4 NDI video feeds 3-4 Camera replays Audio in via Dante
Thanks in advance
Joined: 10/25/2012(UTC) Posts: 181 Location: Barbados
I think the only issue is the use of a Quad 2 card which will require 8 pcie lanes and thunderbolt only provides for 4. You would probably be better off getting two Duo 2 cards.
BTW, where can you find the Beast Canyon NUC 11?
Maxi
they have the NUC 11 Beast Canyon with RTX3060, 1TB storage and 16gb Ram for 2K on https://www.newegg.com/ABS-ALI589/p/83-360-224B&H has the NUC 11 Beast Canyon without a GPU, SSD or Ram for $1200, but I can't find any graphics cards.
Thanks for the info. When I was looking to buy the Nuc 11, either no one had in stock or it was available but no graphic card was available. I bought Laptops instead. I still have 2 or the original Skull canyons in use.
BTW, I use the Duo 2 card in a Sonnet SE 1 which gives me 4 inputs. If I need more inputs I daisy chain 2 of them. That works for me and has the advantage of splitting them across multiple systems if I only need four SDI connections.
Maxi
 1 user thanked Maximus for this useful post.
what's your set up / use with the Skull canyons?
Thank! Jeff
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Thunderbolt 4 is quite bandwidth limited with respect to PCIe. Rather counterintuitively, Thunderbolt 3 is vastly preferable for used with eVGA and PCIe enclosures. With only 1 PCIe lane available, it may not be suitable for use with a capture card.
