hi im looking for an 'automatic' script for weather on vmix. forecast on 5 days for different city? who can help to finf something thanks David
Joined: 4/27/2021(UTC) Posts: 17 Location: Valencia Thanks: 10 times Was thanked: 3 time(s) in 3 post(s)
Joined: 12/27/2012(UTC) Posts: 5,216 Location: Belgium Thanks: 291 times Was thanked: 955 time(s) in 790 post(s)
the "streaming alchemy show" (YT) has a script that does just that
Hi Doggy thanks BUT i see it and try but dont work. Thanks David
Originally Posted by: davidcl Hi Doggy thanks BUT i see it and try but dont work. Thanks David You asked for a script so i assume you are familiar with code and understand what has to be customized for your use ?
not at all i put apikey... but error
Error Line 68: La conversion de la chaîne "52.2" en type 'Double' n'est pas valide.
RealTemp(counter)=Math.Round(CDbl(Temp)).ToString()+"°F"
i have just the city OK after error if i put the lines in comment the script go and i have the other information (i cant have the temperatures)
Thansk Doggy
Please somebody to help me with this error ?? RealTemp(counter)=Math.Round(CDbl(Temp)).ToString()+"°F" error... conversion.... Please. Thanks all
Originally Posted by: davidcl Please somebody to help me with this error ?? RealTemp(counter)=Math.Round(CDbl(Temp)).ToString()+"°F" error... conversion.... Please. Thanks all Check for typos when you changed things , compare with original , can assure you it (the script) works
Thanks but its correct. Maybe because my systeme is in French ? (. , )???
Originally Posted by: davidcl Thanks but its correct. Maybe because my systeme is in French ? (. , )???
Doubt it or do you code with French instructions ? , check the API call link ! there are options in there to consider , the weather website has documentation about it I have it working just fine ( had at one point the same error and was due to a mistake the API call and its return)
