davidcl
#1 Posted : Tuesday, December 7, 2021 7:31:24 AM(UTC)
davidcl
Gabon
hi
im looking for an 'automatic' script for weather on vmix.
forecast on 5 days for different city?
who can help to finf something
thanks
David
ginesromero
#2 Posted : Tuesday, December 14, 2021 4:38:14 AM(UTC)
ginesromero
Spain
#3 Posted : Wednesday, December 15, 2021 3:41:47 AM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
the "streaming alchemy show" (YT) has a script that does just that
davidcl
#4 Posted : Thursday, December 16, 2021 2:46:12 AM(UTC)
davidcl
Gabon
Hi Doggy thanks BUT i see it and try but dont work.
David
#5 Posted : Thursday, December 16, 2021 2:50:43 AM(UTC)
David
You asked for a script so i assume you are familiar with code and understand what has to be customized for your use ?
davidcl
#6 Posted : Thursday, December 16, 2021 3:30:46 AM(UTC)
davidcl
Gabon
not at all
i put apikey...
but error
Error Line 68: La conversion de la chaîne "52.2" en type 'Double' n'est pas valide.
RealTemp(counter)=Math.Round(CDbl(Temp)).ToString()+"°F"
i have just the city OK
after error
if i put the lines in comment
the script go and i have the other information (i cant have the temperatures)
Thansk
Doggy
davidcl
#7 Posted : Thursday, December 23, 2021 3:17:58 AM(UTC)
davidcl
Gabon
Please
somebody to help me with this error
error... conversion....
Please.
Thanks all
#8 Posted : Thursday, December 23, 2021 10:14:23 AM(UTC)
Please
Please.
Thanks all
Check for typos when you changed things , compare with original , can assure you it (the script) works
davidcl
#9 Posted : Friday, December 24, 2021 4:26:08 AM(UTC)
davidcl
Gabon
but its correct.
Maybe because my systeme is in French ?
#10 Posted : Friday, December 24, 2021 4:38:51 AM(UTC)
but its correct.
Doubt it or do you code with French instructions ? , check the API call link ! there are options in there to consider , the weather website has documentation about it
I have it working just fine ( had at one point the same error and was due to a mistake the API call and its return)
Guest (4)
