Joined: 12/10/2021(UTC) Posts: 2  Location: Minneapolis Thanks: 1 times
Is there a way to get rid of the color bars that automatically display when the camera feed I have connected to the computer glitches? I was recently at a live event and the camera feed I was getting was glitching, they weren't able to fix it during the event, so I had to use their feed. Occasionally it would glitch and I would lose the feed. A Color Bar would then appear on the screen. I'd like to figure out how to change that to a Black Screen. That way when the feed glitches, the screen will go to black, and I can decide to switch to a different input without large color bars showing up on the feed I'm outputting. Does anyone know where this setting is or where the COLOR BAR image is, I'm thinking I could just replace that file with a black image. Thanks
What kind of input? we have a BMD Duo as capture card and if the SDI is not OK the input freeze
perhaps it's your capture card which makes the color bar?
 1 user thanked xaver for this useful post.
Right! I didn't even think about it that it could be the capture card. I figured it was a VMIX default. I'll do some research on the capture card and see if it's the problem.
