shaneimagination
#1 Posted : Friday, December 10, 2021 6:17:48 AM(UTC)
shaneimagination
Is there a way to get rid of the color bars that automatically display when the camera feed I have connected to the computer glitches? I was recently at a live event and the camera feed I was getting was glitching, they weren't able to fix it during the event, so I had to use their feed. Occasionally it would glitch and I would lose the feed. A Color Bar would then appear on the screen. I'd like to figure out how to change that to a Black Screen. That way when the feed glitches, the screen will go to black, and I can decide to switch to a different input without large color bars showing up on the feed I'm outputting. Does anyone know where this setting is or where the COLOR BAR image is, I'm thinking I could just replace that file with a black image. Thanks
xaver
#2 Posted : Friday, December 10, 2021 6:54:56 AM(UTC)
xaver
What kind of input?
we have a BMD Duo as capture card and if the SDI is not OK the input freeze
perhaps it's your capture card which makes the color bar?
thanks 1 user thanked xaver for this useful post.
shaneimagination on 12/10/2021(UTC)
shaneimagination
#3 Posted : Friday, December 10, 2021 7:36:27 AM(UTC)
shaneimagination
Right! I didn't even think about it that it could be the capture card. I figured it was a VMIX default. I'll do some research on the capture card and see if it's the problem.
