onelifeonesuit
#1 Posted : Tuesday, November 30, 2021 9:41:27 PM(UTC)
onelifeonesuit
I have the following code as part of a Main/Backstage toggle (thanks to my friend, Matt).
Code:
dim xml as string = API.XML()
dim innum as string = 1
x.loadxml(xml)
dim StateOf as string = (x.SelectSingleNode("//input[@number='1']/@callVideoSource").Value)
In line 5 is it possible to replace the number 1 with the variable "innum"?
I've tried lots of options but my grasp of vb.NET syntax is close to non-existent.
Thanks.
#2 Posted : Tuesday, November 30, 2021 10:09:56 PM(UTC)
Code:
x.loadxml(xml)
Thanks.
Ask Matt ? ;-)
Google has a lot of info about vb.net , working with strings and variables included
Beats throwing something against the wall and see if it sticks ;-)
Code:
dim StateOf as string = (x.SelectSingleNode("//input[@number='" & innum & "']/@callVideoSource").Value
onelifeonesuit
#3 Posted : Tuesday, November 30, 2021 10:22:30 PM(UTC)
onelifeonesuit
Originally Posted by: doggy Go to Quoted Post
Ask Matt ? ;-)
Google has a lot of info about vb.net , working with strings and variables included ;-)
Code:
Haha. I did ask Matt but he couldn't find the answer anywhere. I'll be sure to pass this onto him.
Thanks for your help and quick response. This works a treat.
#4 Posted : Tuesday, November 30, 2021 10:35:33 PM(UTC)
I asked Jeeves ;-)
https://www.codegrepper....%23+string+concatenation
http://www.java2s.com/Co...IntegerintooneString.htm
onelifeonesuit on 11/30/2021(UTC)
