Replace integer with variable when referencing API
Joined: 11/10/2020(UTC) Posts: 10  Location: Glasgow Thanks: 1 times
Hi, I have the following code as part of a Main/Backstage toggle (thanks to my friend, Matt). Code:dim xml as string = API.XML()
dim innum as string = 1
x.loadxml(xml)
dim StateOf as string = (x.SelectSingleNode("//input[@number='1']/@callVideoSource").Value)
In line 5 is it possible to replace the number 1 with the variable "innum"? I've tried lots of options but my grasp of vb.NET syntax is close to non-existent. Thanks.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: onelifeonesuit  Hi, I have the following code as part of a Main/Backstage toggle (thanks to my friend, Matt). Code:dim xml as string = API.XML()
x.loadxml(xml)
In line 5 is it possible to replace the number 1 with the variable "innum"? I've tried lots of options but my grasp of vb.NET syntax is close to non-existent. Thanks. Ask Matt ? ;-) Quote:I've tried lots of options Google has a lot of info about vb.net , working with strings and variables included Beats throwing something against the wall and see if it sticks ;-) Code:dim StateOf as string = (x.SelectSingleNode("//input[@number='" & innum & "']/@callVideoSource").Value
Originally Posted by: doggy  Ask Matt ? ;-) Google has a lot of info about vb.net , working with strings and variables included ;-) Code:dim StateOf as string = (x.SelectSingleNode("//input[@number='" & innum & "']/@callVideoSource").Value
Haha. I did ask Matt but he couldn't find the answer anywhere. I'll be sure to pass this onto him. Thanks for your help and quick response. This works a treat.
