Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Joined: 12/19/2013(UTC) Posts: 590   Location: Belgium Thanks: 76 times Was thanked: 91 time(s) in 75 post(s)
+1 Especially with multi-recorder.
+1
Currently, to synchronize my lighting to a Timecode script in Onyx, I have to use one channel of my video's audio for mono sound, and the other for embedding LTC (Meaning stereo is sacrificed). Sure, I could use a trigger to start a .wav at the same time as the video is started, but this makes it difficult to scrub around while programming the lighting cues, as I can't pause and rewind the video without losing sync.
It would be nice if you could set a time offset on video playback, then vMix just plays it through a common sound device based on the offset of the scrubber.
Joined: 4/9/2020(UTC) Posts: 7  Location: montréal Thanks: 4 times
+1 for timecode (add external generated timecode in VMIX recordings, also for the multicorder). Edited : *add timecode in the metadata, this allows editors to automatically match recordings (vmix, audio, internal camera recordings etc) based on timecode.
Thanks: 12 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: Roeland_QC  *add timecode in the metadata, this allows editors to automatically match recordings (vmix, audio, internal camera recordings etc) based on timecode. +1 Totally agree Roeland. Apparently not that hard to add the feature.
Thanks: 1 times Was thanked: 5 time(s) in 5 post(s)
Joined: 3/31/2022(UTC) Posts: 3  Location: Teresina Thanks: 1 times
Originally Posted by: cmheermann  +1 Especially with multi-recorder.
+1
Originally Posted by: ispyisail  +1 for timecode, especially working in theatrical environments, timecode synchronisation is important.
