Trigger script from VMIX event.
Joined: 7/6/2021(UTC) Posts: 5  Location: Tel Aviv-Yafo Thanks: 1 times
Any idea how to trigger script from internal VMIX event without using external application? Try to control Panasonic RP-150 PTZ controller camera selection, when specific camera is selected on PVW same camera will be selected on the Panasonic controller.
The script for controlling Panasonic PTZ (different script for every camera):
Dim client = WebRequest.create("http://xx.xx.xx.xx/cgi-bin/aw_cam?cmd=XCN:01:1&res=1") Dim response = client.GetResponse()[/b][/b]
If i understand your question correctly :
Script checks which input( camera) is in PVW , performs some logic to triggers in script functions or another script accordingly
yes,
the script need to be triggered from camera PVW event.
every time a specific camera is selected to PVW an http command (as describe above) is send to PTZ controller to change camera
every time a specific camera is selected to PVW an http command (as describe above) is send to PTZ controller to change camera As mentioned before a (constant running) script needs to check what is in PVW . One can pull that information from the API XML in the script https://forums.vmix.com/...86-Scripting-for-Dummies
Joined: 10/22/2020(UTC) Posts: 7  Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
every time a specific camera is selected to PVW an http command (as describe above) is send to PTZ controller to change camera As mentioned before a (constant running) script needs to check what is in PVW . One can pull that information from the API XML in the script https://forums.vmix.com/...86-Scripting-for-Dummies Thought I remembered the same subject passing trough these forums on a earlier moment. Want to take a guess how you handled repetitive questions back then? ;)
