Grappa
#1 Posted : Friday, November 19, 2021 8:55:40 PM(UTC)
Grappa
Israel
Any idea how to trigger script from internal VMIX event without using external application?
Try to control Panasonic RP-150 PTZ controller camera selection, when specific camera is selected on PVW same camera will be selected on the Panasonic controller.
The script for controlling Panasonic PTZ (different script for every camera):
Dim client = WebRequest.create("http://xx.xx.xx.xx/cgi-bin/aw_cam?cmd=XCN:01:1&res=1")
Dim response = client.GetResponse()[/b][/b]
#2 Posted : Friday, November 19, 2021 9:02:48 PM(UTC)
If i understand your question correctly :
Script checks which input( camera) is in PVW , performs some logic to triggers in script functions or another script accordingly
Grappa
#3 Posted : Friday, November 19, 2021 9:15:25 PM(UTC)
Grappa
Israel
yes,
the script need to be triggered from camera PVW event.
every time a specific camera is selected to PVW an http command (as describe above) is send to PTZ controller to change camera
#4 Posted : Friday, November 19, 2021 9:21:40 PM(UTC)
Originally Posted by: Grappa Go to Quoted Post
yes,
As mentioned before a (constant running) script needs to check what is in PVW . One can pull that information from the API XML in the script
https://forums.vmix.com/...86-Scripting-for-Dummies
MTB
#5 Posted : Saturday, November 20, 2021 6:09:05 AM(UTC)
MTB
Nepal
yes,
Thought I remembered the same subject passing trough these forums on a earlier moment.
Want to take a guess how you handled repetitive questions back then? ;)
