Joined: 11/18/2021(UTC) Posts: 8  Location: São Paulo Thanks: 2 times
I'm trying to make a script to help me change the multiviewoverlay in the cartela vemix with 1 person 2 people so on. I made a mix but it was gigantic. As in the image below  Captura de tela 2021-11-17 130740.jpg (257kb) downloaded 3 time(s).Using a 3m script variable I could reduce these buttons to just a few  Captura de tela 2021-11-17 130936.jpg (228kb) downloaded 2 time(s).But for this I would have to create a variable that all my scripts use it. And when you click on 2 pax, for example, this global variable would change and point to a 2-pax card, so on.  Captura de tela 2021-11-17 131240.jpg (194kb) downloaded 3 time(s).Do you have any solution to the question? I did some studies to do this. But I'm stuck on the issue of this global variable and the script to change its value Or create a variable using vMix's SetDinamicInput1 Example Dim cardX = SetDinamicInput1
