Fabianogc
#1 Posted : Thursday, November 18, 2021 2:17:40 AM(UTC)
Fabianogc
Brazil
I'm trying to make a script to help me change the multiviewoverlay in the cartela vemix with 1 person 2 people so on.
I made a mix but it was gigantic. As in the image below
Captura de tela 2021-11-17 130740.jpg (257kb) downloaded 3 time(s).
Using a 3m script variable I could reduce these buttons to just a few
Captura de tela 2021-11-17 130936.jpg (228kb) downloaded 2 time(s).
But for this I would have to create a variable that all my scripts use it.
And when you click on 2 pax, for example, this global variable would change and point to a 2-pax card, so on.
Captura de tela 2021-11-17 131240.jpg (194kb) downloaded 3 time(s).
Do you have any solution to the question?
I did some studies to do this. But I'm stuck on the issue of this global variable and the script to change its value
Or create a variable using vMix's SetDinamicInput1
Example
Dim cardX = SetDinamicInput1
#2 Posted : Thursday, November 18, 2021 3:30:28 AM(UTC)
https://www.vmix.com/hel...tm?DynamicShortcuts.html
Small example : https://forums.vmix.com/...ng-for-Dummies#post88552
More elaborate is putting multiple values in there and retrieve them with a script by reading the API XML and process
A more complex use to simplify things example
