Hello everyone of the staff. I have used at work the vMix. This is a great software. I think I am often use the playlist function of vMix, but the playlist that proceeds at a time rather than the duration that I needed.
Specifically, the playlist will start automatically Once the time it was decided, subsequent events it is also a function, such as going to transition at the specified time.
Please consider to be equipped with this feature.
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
Thank you all! Software that you have introduced me to had the features I was looking for. But the software does not seem to work with Windows8.1. It is a pity but to utilize a standard feature of the playlist.
Again, thank you.
