clair
#1 Posted : Friday, May 30, 2014 1:04:01 PM(UTC)
clair
Hello everyone of the staff.
I have used at work the vMix. This is a great software.
I think I am often use the playlist function of vMix, but the playlist that proceeds at a time rather than the duration that I needed.
Specifically, the playlist will start automatically Once the time it was decided, subsequent events it is also a function, such as going to transition at the specified time.
Please consider to be equipped with this feature.
#2 Posted : Friday, May 30, 2014 4:24:37 PM(UTC)
Have you tried the "vMixscheduler"?
http://forums.vmix.com.a...t.aspx?g=posts&t=999
Sounds like it might do what you want...
clair on 6/1/2014(UTC)
clair
#3 Posted : Sunday, June 1, 2014 7:35:09 AM(UTC)
clair
Thank you all!
Software that you have introduced me to had the features I was looking for.
But the software does not seem to work with Windows8.1.
It is a pity but to utilize a standard feature of the playlist.
Again, thank you.
