ThomasWallis
#1 Posted : Saturday, November 13, 2021 5:36:18 AM(UTC)
ThomasWallis
I am running Vmix on a machine with a Duo 2 card for capture.
Inputs 1 and 2 come in just fine but when I try to add Inputs 3 and 4 I am getting the 'Format Is Not Supported' error message.
This makes no sense to me since 2 of the inputs on the card are working fine with the selected project settings.
I've made sure that there are no devices selected for external output.
I've reinstalled Blackmagic Drivers. Not sure what else to do.
Has anyone else seen this?
OS: Windows 10 Pro
CPU: AMD Ryzen Threadripper 1950x
GPU: Nvidia Geforce GTX 1080 Ti
Vmix Version: 24.0.0.72
MartLeib
#2 Posted : Saturday, November 13, 2021 8:12:05 AM(UTC)
MartLeib
Estonia
Open Desktop Video Setup (search in start), go through all the inputs, in the settings open Connectors/Connections tab, and select SDI (n) for each one. Done.
thanks 1 user thanked MartLeib for this useful post.
ThomasWallis on 12/5/2021(UTC)
ThomasWallis
#3 Posted : Sunday, December 5, 2021 8:53:34 AM(UTC)
ThomasWallis
Thanks this was the fix I was looking for!
