melody
#1 Posted : Tuesday, November 9, 2021 2:26:23 AM(UTC)
Rank: Guest
Groups: Guests
Recently, i needed to Record the multiview just to watch later with multimedia team to understand what can be improved... When i changed the output from "program" to "multiview", it changed also my fullscreen from "multiview" to "program" and i cannot see the multiview on fullscreen when multiview is selected on output. However, recording was fine.
Maybe, this can be simple to fix.
Merry Christmas
Melody
#2 Posted : Tuesday, November 9, 2021 8:54:02 PM(UTC)
@ Melody
By design, the vMix main Program Output has to go to one of two places: Fullscreen 1 or Output 1, typically, this is to Output 1 for Record/Stream/External.
If Output 1 gets changed (for whatever reason), vMix will by default send that feed to Fullscreen 1 and not allow you to change it.
melody
#3 Posted : Thursday, November 11, 2021 3:51:08 AM(UTC)
Rank: Guest
Groups: Guests
I understand, but that sounds like an issue... when i select program to fullscreen 1 and output 1 (recording/streaming/etc...) it works fine... not the same when i select multiview for both places, fullscreen keeps going to program automatically,
#4 Posted : Thursday, November 11, 2021 6:38:59 AM(UTC)
@ melody
Again, that is by design.
99.9% of the time, Output 1 will be (or should be) set to the main vMix Program "Output", which gives you the freedom to configure Fullscreen 1 to any screen in vMix.
It's only when you configure Output 1 to somethings else that the Fullscreen 1 gets locked to "Output" only.
