Recording fullscreen/multiview issue
Rank: Guest
Groups: Guests
Recently, i needed to Record the multiview just to watch later with multimedia team to understand what can be improved... When i changed the output from "program" to "multiview", it changed also my fullscreen from "multiview" to "program" and i cannot see the multiview on fullscreen when multiview is selected on output. However, recording was fine.
Maybe, this can be simple to fix.
Merry Christmas
Melody
@ Melody
By design, the vMix main Program Output has to go to one of two places: Fullscreen 1 or Output 1, typically, this is to Output 1 for Record/Stream/External. If Output 1 gets changed (for whatever reason), vMix will by default send that feed to Fullscreen 1 and not allow you to change it.
Rank: Guest
Groups: Guests
I understand, but that sounds like an issue... when i select program to fullscreen 1 and output 1 (recording/streaming/etc...) it works fine... not the same when i select multiview for both places, fullscreen keeps going to program automatically,
@ melody
Again, that is by design. 99.9% of the time, Output 1 will be (or should be) set to the main vMix Program "Output", which gives you the freedom to configure Fullscreen 1 to any screen in vMix. It's only when you configure Output 1 to somethings else that the Fullscreen 1 gets locked to "Output" only.
