davidcl
#1 Posted : Tuesday, November 9, 2021 4:38:11 AM(UTC)
davidcl
Gabon
Hi all
i try to put trigger on a 'list' with video/picture in it but dont work?
i want to ' audio off' for example for some video in the track list.
is t normal?
thanks
#2 Posted : Tuesday, November 9, 2021 5:26:56 AM(UTC)
Originally Posted by: davidcl Go to Quoted Post
is t normal?
What do you want to trigger it on that could apply to an individual item of an (list) input ?
davidcl
#3 Posted : Tuesday, November 9, 2021 5:41:36 AM(UTC)
davidcl
Gabon
I have a list with video/picture/jingle/....
for some i received i dont want to send the sound only the video (for some not all)
when i make a trigger ontransitionin / audiooff / <diffusionLIST> / <clip name xx>
doenst work?
thanks
#4 Posted : Tuesday, November 9, 2021 6:41:08 AM(UTC)
doenst work?
thanks
and on what is a decision based to trigger the audio off ?
BTW the triggers work on the input ( the list input) itself, not its items !
But you could use some scripting if you wanted to invest in that but you would really need to figure out the detailed process and decision making first ( computers are dumb ;-) )
davidcl
#5 Posted : Tuesday, November 9, 2021 7:05:16 AM(UTC)
davidcl
Gabon
trig list.PNG (19kb) downloaded 0 time(s).
ok i see
but why this 'option' is possible?
trigger on a clip in a list?
or i see bad?
davidcl
#6 Posted : Wednesday, November 10, 2021 7:00:37 AM(UTC)
davidcl
Gabon
on this nothing???
thanks....
#7 Posted : Wednesday, November 10, 2021 11:11:11 PM(UTC)
@ davidci
That Video dropdown box is a little misleading.
It is only there because it is part of the Input, like a sub-folder within the Input and is only informational, it otherwise has no functionality with regards to the Trigger settings.
(if it did, there would be a "column" for it in the above settings parameters)
Joeboe
#8 Posted : Wednesday, November 10, 2021 11:33:08 PM(UTC)
Joeboe
I do a lot of this stuff....what you have to do is make 2 play lists, one for clips with audio, and one without, so that when you apply a trigger for no audio, only that list will be muted, for audio on, you will use the playlist that you need audio from,...simple....Like I said, I do that often....no issues.
