Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hi all i try to put trigger on a 'list' with video/picture in it but dont work? i want to ' audio off' for example for some video in the track list.
is t normal?
thanks
Originally Posted by: davidcl  is t normal?
What do you want to trigger it on that could apply to an individual item of an (list) input ?
I have a list with video/picture/jingle/....
for some i received i dont want to send the sound only the video (for some not all)
when i make a trigger ontransitionin / audiooff / <diffusionLIST> / <clip name xx>
doenst work? thanks
doenst work? thanks and on what is a decision based to trigger the audio off ? BTW the triggers work on the input ( the list input) itself, not its items ! But you could use some scripting if you wanted to invest in that but you would really need to figure out the detailed process and decision making first ( computers are dumb ;-) )
 trig list.PNG (19kb) downloaded 0 time(s).ok i see but why this 'option' is possible? trigger on a clip in a list? or i see bad?
on this nothing??? thanks....
@ davidci
That Video dropdown box is a little misleading. It is only there because it is part of the Input, like a sub-folder within the Input and is only informational, it otherwise has no functionality with regards to the Trigger settings. (if it did, there would be a "column" for it in the above settings parameters)
I do a lot of this stuff....what you have to do is make 2 play lists, one for clips with audio, and one without, so that when you apply a trigger for no audio, only that list will be muted, for audio on, you will use the playlist that you need audio from,...simple....Like I said, I do that often....no issues.
