svetotehnik
#1 Posted : Wednesday, November 3, 2021 11:21:00 PM(UTC)
svetotehnik
Russian Federation
I need to get timecode of input, this code works:
Code:
dim xml as string = API.XML()
x.loadxml(xml)
dim time_position as string = (x.SelectSingleNode("//input[@number=1]/@position").Value)
but if I need to set number of active input it returns exception:
Code:
x.loadxml(xml)
dim active_input as string = (x.SelectSingleNode("//active").InnerText)
dim time_position as string = (x.SelectSingleNode("//input[@number=active_input]/@position").Value)
tried to change to integer, also doesnt work. when write to console input determinates correctly
thank you!
Papo
#2 Posted : Thursday, November 4, 2021 10:40:16 AM(UTC)
Papo
Peru
At first glance you can see that the xpath has a variable inside in this case active_input, you have to separate that variable from everything and or concatenate it.
translated from spanish with google
GregS
#3 Posted : Thursday, November 4, 2021 11:29:43 AM(UTC)
GregS
Canada
The reason your command is not working is because it is looking for an input numbered "time_position", rather than the value of time_position.
To do what you want try the following commands:
x.loadxml(xml)
x.loadxml(xml)
dim position_query as string = "//input[@number=" + time_position + "]/@position"
dim time_position as string = (state.SelectSingleNode(position_query).Value)
creates the query string that contains the value of time_position e.g. "//input[@number=1]/@position".
performs the xml query to return the position value.
thanks 1 user thanked GregS for this useful post.
svetotehnik on 11/4/2021(UTC)
svetotehnik
#4 Posted : Thursday, November 4, 2021 2:37:30 PM(UTC)
svetotehnik
Russian Federation
Thank you very much!
I still don't quite understand how it works, but it does)
Code:
x.loadxml(xml)
dim xml2 as string = API.XML()
dim x2 as new system.xml.xmldocument
x2.loadxml(xml)
dim position_query as string = "//input[@number=" + active_input + "]/@position"
dim time_position as string = (x2.SelectSingleNode(position_query).Value)
#5 Posted : Thursday, November 4, 2021 5:00:34 PM(UTC)
Code:
x.loadxml(xml)
dim time_position as string = (x.SelectSingleNode("//input[@number=" + active_input + "]/@position").Value)
Console.writeline(time_position )
