Variable instead of integer in scripting
Joined: 11/6/2020(UTC) Posts: 21  Location: Saint-Petersburg Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
I need to get timecode of input, this code works: Code:dim xml as string = API.XML()
x.loadxml(xml)
dim time_position as string = (x.SelectSingleNode("//input[@number=1]/@position").Value)
but if I need to set number of active input it returns exception: Code:dim xml as string = API.XML()
x.loadxml(xml)
dim active_input as string = (x.SelectSingleNode("//active").InnerText)
dim time_position as string = (x.SelectSingleNode("//input[@number=active_input]/@position").Value)
tried to change to integer, also doesnt work. when write to console input determinates correctly thank you!
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
At first glance you can see that the xpath has a variable inside in this case active_input, you have to separate that variable from everything and or concatenate it. translated from spanish with google
Joined: 10/20/2021(UTC) Posts: 5  Location: Ontario Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
The reason your command is not working is because it is looking for an input numbered "time_position", rather than the value of time_position. To do what you want try the following commands: Quote: dim xml as string = API.XML() dim x as new system.xml.xmldocument x.loadxml(xml)
dim position_query as string = "//input[@number=" + time_position + "]/@position" dim time_position as string = (state.SelectSingleNode(position_query).Value)
dim position_query as string = "//input[@number=" + time_position + "]/@position"creates the query string that contains the value of time_position e.g. "//input[@number=1]/@position". dim time_position as string = (state.SelectSingleNode(position_query).Value) performs the xml query to return the position value.
 1 user thanked GregS for this useful post.
Originally Posted by: GregS  The reason your command is not working is because it is looking for an input numbered "time_position", rather than the value of time_position Thank you very much! I still don't quite understand how it works, but it does) Code:dim xml as string = API.XML()
x.loadxml(xml)
dim xml2 as string = API.XML()
dim x2 as new system.xml.xmldocument
x2.loadxml(xml)
dim position_query as string = "//input[@number=" + active_input + "]/@position"
dim time_position as string = (x2.SelectSingleNode(position_query).Value)
x.loadxml(xml)
dim time_position as string = (x.SelectSingleNode("//input[@number=" + active_input + "]/@position").Value)
Console.writeline(time_position )
