Machtl
#1 Posted : Tuesday, November 2, 2021 12:29:11 AM(UTC)
Machtl
Austria
Please make also commands for the Tally Lights. So especially Multilayered Scenes/Inputs can be used together with triggers to set the correct Tally lights for the cams.
richardgatarski
#2 Posted : Tuesday, November 16, 2021 8:55:24 PM(UTC)
richardgatarski
+1 (and Machtl, do you perhaps mean "shortcuts" instead of "actions" in the name of this topic?)
Our use case is the use of Mix2-4. I think that with the possibility to set a Tally number with a shortcut using a DynamicInput we could finally be able to have the correct light on, as we control the Mix inputs via scripts and shortcuts.
And we are not alone in this need, I found at least three more Feature Requests on this issue:
https://forums.vmix.com/...-Tally-work-with-mixer-2
https://forums.vmix.com/...y-lights-with-Mix-inputs
https://forums.vmix.com/...Mix2-and-subsquent-buses
thanks,
/richard
Machtl
#3 Posted : Tuesday, November 16, 2021 11:12:22 PM(UTC)
Machtl
Austria
two ways would be nice:
1.) activator: so if for example Input X is live -> set Tally 1 to RED. if Input Y is live -> set Tally 1 and Tally 2 to RED (PiP Input)
2.) trigger in an input: also it would be nice to directly do this in the trigger settings of an input. for example: OnTransitionIn -> set Tally 1 to RED
