matteoarrigone
#1 Posted : Thursday, January 30, 2020 8:47:19 PM(UTC)
matteoarrigone
I would like to use tally lights with Mix 2 or 3 or 4. I explain my situation. I've got a production with split-screens and I'm using mix inputs to manage what is inside the boxes and it's fine. But the problem is that when a camera is on program in Mix 1 the tally light turn on but when a camera is on program in Mix 2 (or 3 or 4) and Mix 2 is on program in Mix 1 the tally light doesn't turn on.
Matteo Arrigone
RobSealey
#2 Posted : Wednesday, March 10, 2021 7:45:32 PM(UTC)
RobSealey
Matteo Arrigone
Hi there, did you ever get a solution to this issue - I have the same problem.
Rob
Cali_Chris
#3 Posted : Thursday, March 18, 2021 1:17:36 AM(UTC)
Cali_Chris
Rank:: Newbie
BUMP - This is a big issue. No tally support for cameras in Mix 2, 3, 4. It is, as far as I can tell, nonexistent. How are we supposed to tally cameras. In switchers, you can turn on or off Tally ability on MEs. Does anyone think API access can give us access to track tally on Mix2, Mix3, Mix4?
carlofornasari
#4 Posted : Thursday, March 18, 2021 2:36:31 PM(UTC)
carlofornasari
+1
Tally should respond to all MEs.
b78
#5 Posted : Friday, April 8, 2022 12:58:18 AM(UTC)
b78
Czech Republic
Maybe it would be enough for Tally to start if the input got to output via mix2.
KJPark
#6 Posted : Wednesday, April 13, 2022 8:13:38 PM(UTC)
KJPark
Norway
I think the easiest would be that the Tally light could activate if the input source is visible in a program out, either Mix 1,2,3 or 4.
This way it will light up if it is an output regardless of where. Should also be an option to deactivate tally on each mix individually if needed.
