vMix Call
Use call with no camera
We had a broadcast this weekend where we had a guest who would talk into the broadcast via his computer in speech. However, it was not possible to connect to the broadcast because the guest did not have a camera on their computer. Is there a solution to this? For a call is a call even without a camera?
Regards Andreas
Joined: 7/1/2020(UTC) Posts: 106  Location: Earth Was thanked: 23 time(s) in 20 post(s)
vMixCall won't connect without a camera present
Yep, won't work without 'seeing' a webcam. One workaround would be to have them install OBS, and turn on the 'Webcam' output so there is a virtual 'camera' vmixcall can see. I put in a similar feature request a bit ago, as we often use vmixcall for easy remote multi-viewer access. : https://forums.vmix.com/...ix-call--view-only--feed
I find it strange that a camera is required to be able to connect with a call. You must be able to call guests without them having to have a device with a webcam or having OBS installed.
Is this something you might have changed in the future?
Above all, it is a good function to have an external monitor. You can run NDI, but not all places where you can't sit on the same network.
vMix Call
