andy987
#1 Posted : Monday, October 25, 2021 9:30:12 PM(UTC)
andy987
Sweden
We had a broadcast this weekend where we had a guest who would talk into the broadcast via his computer in speech. However, it was not possible to connect to the broadcast because the guest did not have a camera on their computer. Is there a solution to this? For a call is a call even without a camera?
Regards Andreas
AudioGreg
#2 Posted : Tuesday, October 26, 2021 2:07:46 AM(UTC)
AudioGreg
Was thanked: 23 time(s) in 20 post(s)
vMixCall won't connect without a camera present
David Krug
#3 Posted : Tuesday, October 26, 2021 2:24:50 AM(UTC)
David Krug
Yep, won't work without 'seeing' a webcam.
One workaround would be to have them install OBS, and turn on the 'Webcam' output so there is a virtual 'camera' vmixcall can see.
I put in a similar feature request a bit ago, as we often use vmixcall for easy remote multi-viewer access. :
https://forums.vmix.com/...ix-call--view-only--feed
andy987
#4 Posted : Tuesday, October 26, 2021 5:03:14 AM(UTC)
andy987
Sweden
I find it strange that a camera is required to be able to connect with a call. You must be able to call guests without them having to have a device with a webcam or having OBS installed.
Is this something you might have changed in the future?
Above all, it is a good function to have an external monitor. You can run NDI, but not all places where you can't sit on the same network.
