Joined: 10/25/2021(UTC) Posts: 2  Location: Healesville
I have created a short title sequence video using DNxHR 444 12-bit and a similar one using CineForm RGB 16-bit (both with alpha export on). When I bring the MOV files into my NLE, they clearly have an alpha channel. Yet, I don't get transparency when I bring it into vMix. Any thoughts on what I might be doing wrong? BTW, I'm a newbie, so the potential for doing something wrong is high!
Thanks for you help!
Originally Posted by: doggy  what does the vMix Video Tool to convert the .MOV file to an image sequence do ? It gives me this error message... [img=https://jeffschwisow-my.sharepoint.com/:i:/p/jeff/ES9naFwQ5hlFlPSQq4zu6V8BUlWg4DE-2VhLj2ZHlpxk9A?e=OxUwB7]Error message[/img] Thanks for the links...I'll check them out and see if there's something I can glean from them.
