Plamen
#1 Posted : Sunday, October 24, 2021 10:11:36 AM(UTC)
Plamen
Hey all,
Are the values of any color correction applied to VMix inputs output anywhere that could be caught by the API? I've looked through the XML and can't seem to notice anything in the input parameters that corresponds to the color values.
Thanks!
#2 Posted : Sunday, October 24, 2021 11:24:46 AM(UTC)
Maybe try the last,vmix preset XML file.
Mind you it does not update instantly with changes as it's not intended for such use
Plamen
#3 Posted : Sunday, October 24, 2021 11:28:15 AM(UTC)
Plamen
Where is this file located or what API command can I send to view it? I thought it might be helpful, but was not able to find it in my search yesterday.
Thanks!
#4 Posted : Sunday, October 24, 2021 3:26:20 PM(UTC)
File Explorer search says something like C:/Users/something/something/...
Ther is no direct API command. you will need to read the xml file and pull the appropriate bits you want from it (Xpath stuff)
