Color Correction Values accessible via API?
Hey all,
Are the values of any color correction applied to VMix inputs output anywhere that could be caught by the API? I've looked through the XML and can't seem to notice anything in the input parameters that corresponds to the color values.
Thanks!
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Maybe try the last,vmix preset XML file. Mind you it does not update instantly with changes as it's not intended for such use
Originally Posted by: doggy  Maybe try the last,vmix preset XML file. Mind you it does not update instantly with changes as it's not intended for such use Where is this file located or what API command can I send to view it? I thought it might be helpful, but was not able to find it in my search yesterday. Thanks!
Originally Posted by: Plamen  Where is this file located or what API command can I send to view it? I thought it might be helpful, but was not able to find it in my search yesterday.
File Explorer search says something like C:/Users/something/something/... Ther is no direct API command. you will need to read the xml file and pull the appropriate bits you want from it (Xpath stuff)
