Mr.Shamil
#1 Posted : Thursday, October 7, 2021 3:52:10 AM(UTC)
Mr.Shamil
Azerbaijan
20211006_200530.png (257kb) downloaded 4 time(s). 20211006_200514.png (259kb) downloaded 5 time(s).Hi, there. I have tried to create lower 3rd just as the same as on the attached files for a long time, whereas I have failed. Is there any ways to create the mentioned lower 3rd?
1) The headlines comes forward with a big letters
2) Then it goes to a minimised position and The description appears.
#2 Posted : Thursday, October 7, 2021 4:06:24 AM(UTC)
as in how ? fades in , zooms in .............
2)The description appears.
again how ?
But generally in this case one is better off using other design, animation software and make an image sequence out of it or use legacy XAML title design
Mr.Shamil
#3 Posted : Saturday, October 23, 2021 12:42:14 AM(UTC)
Mr.Shamil
Azerbaijan
1) as it is shown on the pic, firstly a HEADER comes forward with a bigger alphabet.
2) then a Header gets back to its position with smaller alphabets and a DESCRIPTION appears below of HEADER.
is it possible to accomplish all these procedures on GT Title Desginer, without using any Animation Software etc. ?
#4 Posted : Saturday, October 23, 2021 3:49:28 AM(UTC)
From where like initial cut, fade or ... , initial size? ... (yep an still images shows how it starts, moves etc )
How, fade, moves in ... what? again when ? timedelay ?
Doubtful, but never say never. will depend a lot on your answers
Mr.Shamil
#5 Posted : Saturday, October 23, 2021 8:37:09 PM(UTC)
Mr.Shamil
Azerbaijan
well, HEADER with bigger alphabets (white backgrounds) cuts on the air after 7 seconds it shrinks down and a description fades in.
#6 Posted : Saturday, October 23, 2021 9:11:16 PM(UTC)
Lets see
Within GT title one can simulate the resizing for a rectangle and an image and then some delicate trickery but to effect looks like SH** for text (does not resize) .
Legacy XAML title (design with blend) with "timeline" animations can achieve this with it's own limitations or look for a different effect if one want to stick with GT
Mr.Shamil
#7 Posted : Saturday, October 23, 2021 11:17:08 PM(UTC)
Mr.Shamil
Azerbaijan
Thanks for your help, really appreciate that, the same procedure that I was looking for ages.
Could you attach the GT title file, please?
#8 Posted : Saturday, October 23, 2021 11:53:58 PM(UTC)
No as it is not a GT title for reasons as explained before, its a XAML title (without paying attention to details) created with visual Studio Blend
