 20211006_200530.png (257kb) downloaded 4 time(s). 20211006_200514.png (259kb) downloaded 5 time(s).Hi, there. I have tried to create lower 3rd just as the same as on the attached files for a long time, whereas I have failed. Is there any ways to create the mentioned lower 3rd? 1) The headlines comes forward with a big letters 2) Then it goes to a minimised position and The description appears.
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Mr.Shamil  1) The headlines comes forward with a big letters
as in how ? fades in , zooms in ............. Quote: 2)The description appears.
again how ? But generally in this case one is better off using other design, animation software and make an image sequence out of it or use legacy XAML title design
1) as it is shown on the pic, firstly a HEADER comes forward with a bigger alphabet. 2) then a Header gets back to its position with smaller alphabets and a DESCRIPTION appears below of HEADER.
is it possible to accomplish all these procedures on GT Title Desginer, without using any Animation Software etc. ?
Originally Posted by: Mr.Shamil  1) as it is shown on the pic, firstly a HEADER comes forward with a bigger alphabet. From where like initial cut, fade or ... , initial size? ... (yep an still images shows how it starts, moves etc ) Quote:2) then a Header gets back to its position with smaller alphabets and a DESCRIPTION appears below of HEADER. How, fade, moves in ... what? again when ? timedelay ? Quote:is it possible to accomplish all these procedures on GT Title Desginer, without using any Animation Software etc. ?
Doubtful, but never say never. will depend a lot on your answers
well, HEADER with bigger alphabets (white backgrounds) cuts on the air after 7 seconds it shrinks down and a description fades in.
Originally Posted by: Mr.Shamil  well, HEADER with bigger alphabets (white backgrounds) cuts on the air after 7 seconds it shrinks down and a description fades in. Lets see Within GT title one can simulate the resizing for a rectangle and an image and then some delicate trickery but to effect looks like SH** for text (does not resize) . Legacy XAML title (design with blend) with "timeline" animations can achieve this with it's own limitations or look for a different effect if one want to stick with GT
Thanks for your help, really appreciate that, the same procedure that I was looking for ages. Could you attach the GT title file, please?
Originally Posted by: Mr.Shamil  Thanks for your help, really appreciate that, the same procedure that I was looking for ages. Could you attach the GT title file, please? No as it is not a GT title for reasons as explained before, its a XAML title (without paying attention to details) created with visual Studio Blend
