Toldorn
#1 Posted : Friday, October 22, 2021 9:55:12 AM(UTC)
Toldorn
Hi team,
Working with an animated PNG sequence, and I come from an After Effects background.
I'm trying to do a really simple title that has text move from position A on screen, to position B on screen.
Can someone explain how - rather than using the crappy PowerPoint-looking animations?
I don't want to render out commentary titles from AE during the event, as it'll be changing lots and lots - so I need to be able to edit the names in Vmix.
thanks!
#2 Posted : Friday, October 22, 2021 1:55:55 PM(UTC)
Animated (move or appearing) ? jump? based on ?
Meaning ?
Manually or using datasources or ?
Toldorn
#3 Posted : Friday, October 22, 2021 2:02:30 PM(UTC)
Toldorn
Like this;
http://www.tropicalexposure.com.au/test.mp4
The orange BG is a PNG sequence, and I just need my GT Title text to start in position A.... move to position B...then after 5/6/7 seconds, return to position A.
A very simple animation - but i need to be able to change the text within Vmix. Pre-Rendering the titles isn't an option.
#4 Posted : Friday, October 22, 2021 5:21:02 PM(UTC)
Like this;
Might work with some trickery in a GT title. However you didn't mention when the animation has to take place
Toldorn
#5 Posted : Friday, October 22, 2021 5:37:11 PM(UTC)
Toldorn
What you see is hidden behind a scoreboard element. When I click overlay 2 I want it to appear from behind the scoreboard, display for 10 seconds then duck down behind again.
#6 Posted : Friday, October 22, 2021 7:42:36 PM(UTC)
OH!
Now it has to appear from somewhere behind and has to stay 10 seconds. that is NOT the same as your example/initial post, in fact completely different to achieve with the title designer
Still haven't mentioned the criteria for it to appear .
Why even bother trying to sync a title text animation with an image sequence
Its simple alright hence asking here LOL
Left: duplicating items, hide duplicate , fly main item, animation with exact timing for it to hide and unhide the duplicate to make it appear it moved , stayed and returned
Right: fly in from behind other item using a mask , delay and fly back out
Both on datachange
