Feature Requests
Change Z-order of multiview layers via API
It is possible to reorder the z-index of layers in the multivew tab by dragging and dropping layers, would be awesome if this could be done via the API aswell. Here is the related documentation: https://www.vmix.com/hel...utSettingsMultiView.htmlMove / Change Order
Overlays can be moved to different numbers by dragging and dropping the number boxes.  Moving an Overlay will change its order while preserving all position and cropping information. This is useful in situations where you want to move an Input so that it appears "on top" of another where 10 is the top most layer. (This is also known as the Z-Index, or Z-Order)
Joined: 11/30/2013(UTC) Posts: 165 Location: Seoul, South Korea
Thanks: 39 times Was thanked: 19 time(s) in 14 post(s)
Hello, you should check the "MoveLayer" shortcut in the API. I think this does what you are requesting.
Feature Requests
