	Instant Replay
	Instant replay export with commentator audio
 Joined: 5/16/2020(UTC) Views messages in topic : 38  Location: Trondheim Thanks: 2 times
                I need to export replays after each match. I do this as one continuous clip (not individual clips). I have the commentator on an audio input that goes to Master.
  When I export, there is no audio at all. How can I export with the Master track audio?
 Joined: 12/4/2019(UTC) Posts: 23  Was thanked: 1 time(s) in 1 post(s)
                Look to Replay settings. There is setting for audio source for replays. If you set to Master, all your clip will be pith master sound
                Thank you for the reply.
  Unfortunately that doesn´t work. I was expecting that option to do just what I´m trying to do but instead I just get a clip with no sound at all. Am I looking at a bug or are we just misunderstaning what that option does?
                bump. Is no one else having this problem?
                to get your audio, you also have to record the audio is the commentator on Camera 1 (Your NDI..) or Camrera 2 (your CAM1)? if not, record the audio of the commentator as Camera 3
	Instant Replay
