nidarosvideo
#1 Posted : Monday, October 11, 2021 2:22:26 AM(UTC)
nidarosvideo
Norway
I need to export replays after each match. I do this as one continuous clip (not individual clips).
I have the commentator on an audio input that goes to Master.
When I export, there is no audio at all.
How can I export with the Master track audio?
gorbva
#2 Posted : Monday, October 18, 2021 9:04:18 PM(UTC)
gorbva
Kazakhstan
Look to Replay settings. There is setting for audio source for replays. If you set to Master, all your clip will be pith master sound
nidarosvideo
#3 Posted : Monday, October 18, 2021 11:38:06 PM(UTC)
nidarosvideo
Norway
Thank you for the reply.
Unfortunately that doesn´t work. I was expecting that option to do just what I´m trying to do but instead I just get a clip with no sound at all.
Am I looking at a bug or are we just misunderstaning what that option does?
SportsNetUSA.net
#4 Posted : Tuesday, October 19, 2021 8:21:25 AM(UTC)
SportsNetUSA.net
What is you audio playback source set to? As gorbva replied, is it on Master or on one of your cameras?
https://www.vmix.com/help24/index.htm?GettingStarted1.html
nidarosvideo
#5 Posted : Monday, November 15, 2021 12:22:51 AM(UTC)
nidarosvideo
Norway
nidarosvideo
#6 Posted : Tuesday, December 28, 2021 10:30:27 PM(UTC)
nidarosvideo
Norway
bump.
Is no one else having this problem?
xaver
#7 Posted : Wednesday, December 29, 2021 5:52:16 AM(UTC)
xaver
to get your audio, you also have to record the audio
is the commentator on Camera 1 (Your NDI..) or Camrera 2 (your CAM1)?
if not, record the audio of the commentator as Camera 3
Guest (6)
