BigApple
#1 Posted : Monday, October 18, 2021 11:50:05 AM(UTC)
BigApple
Does anyone know if it is possible to switch out Stream Decks and keep the shortcuts still going ? it tried a different StreamDeck XL and the shortcuts it seems need to be assigned to the buttons all over. Has anyone found a way to avoid this hassle. Or did i miss something.. I copied the entire profiles over to the new unit... The buttons are all there but the shortcuts no longer respond as they are waiting for the old units shortcuts Keys.
#2 Posted : Monday, October 18, 2021 5:53:36 PM(UTC)
Using the vMix plugin ? Than will have to reassign the buttons.
Not using the vMix plugin (using SD hotkeys and/or website)? Can easily transfer a profile to another streamdeck or pc
Each has pro and cons
