Switching Stream Decks (keep Shortcuts?)
Does anyone know if it is possible to switch out Stream Decks and keep the shortcuts still going ? it tried a different StreamDeck XL and the shortcuts it seems need to be assigned to the buttons all over. Has anyone found a way to avoid this hassle. Or did i miss something.. I copied the entire profiles over to the new unit... The buttons are all there but the shortcuts no longer respond as they are waiting for the old units shortcuts Keys.
Originally Posted by: BigApple  Does anyone know if it is possible to switch out Stream Decks and keep the shortcuts still going ? it tried a different StreamDeck XL and the shortcuts it seems need to be assigned to the buttons all over. Has anyone found a way to avoid this hassle. Or did i miss something.. I copied the entire profiles over to the new unit... The buttons are all there but the shortcuts no longer respond as they are waiting for the old units shortcuts Keys. Using the vMix plugin ? Than will have to reassign the buttons. Not using the vMix plugin (using SD hotkeys and/or website)? Can easily transfer a profile to another streamdeck or pc Each has pro and cons
