davidcl
#1 Posted : Wednesday, September 29, 2021 9:50:30 PM(UTC)
davidcl
Gabon
Hi
i have a lower third empty (sequence imge on my CG) (8 secondes)
i want to ADD name on it
its ok to write name
BUT i want that the text disapear when i my lowerthird go out
i dont know if you see what i want to explain..
(sorry for my english)
vMix Capture 29 septembre 2021 12-33-33.png (1,449kb) downloaded 0 time(s).
#2 Posted : Wednesday, September 29, 2021 10:09:36 PM(UTC)
Have you checked the vmix video tutorials?
Also maybe have that text on the same layer your animating
davidcl
#3 Posted : Wednesday, September 29, 2021 11:29:14 PM(UTC)
davidcl
Gabon
yes i check vMix tuto
but my problem the lower third is not make on CG its a video with alpha ( sequence image)
so i dont have a all anim track
#4 Posted : Thursday, September 30, 2021 12:17:00 AM(UTC)
Guess one wil have to animate the text synchronized with the image sequence
davidcl
#5 Posted: : Thursday, September 30, 2021 1:32:39 AM(UTC)
davidcl
Gabon
i found a solution (but its not very good)
i dont use all the sequence of the lower third....
i use only when coming i put the name and overlay go out out.. i dont have all the 8s of my lower third.
#6 Posted : Thursday, September 30, 2021 2:51:22 AM(UTC)
https://translate.google.com/
davidcl
#7 Posted : Thursday, September 30, 2021 3:31:06 AM(UTC)
davidcl
Gabon
In fact I found a solution but which is not what I want.
I cut my file in half (sequential) so that I only have the appearance. and I make my 2 names appear. and then in OVERLAY / duration / 6s so that it disappears on its own.
My wish would have been that all the sequence that I received from elsewhere (Lower third) is visible with the names that disappear ..
#8 Posted : Thursday, September 30, 2021 3:37:38 AM(UTC)
you will need to synchronize the animations of the text with the animation of the image sequence be it for coming in and coming out (TransitionIn and transition out )
do you have the files available ?
davidcl
#9 Posted : Thursday, September 30, 2021 4:33:56 AM(UTC)
davidcl
Gabon
i dont know why the .RAR less 5M dont want to upload here?
