GT
Lower third empty / CG text
Joined: 12/23/2018(UTC) Posts: 120   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hi i have a lower third empty (sequence imge on my CG) (8 secondes) i want to ADD name on it its ok to write name BUT i want that the text disapear when i my lowerthird go out i dont know if you see what i want to explain.. (sorry for my english) Thanks  vMix Capture 29 septembre 2021 12-33-33.png (1,449kb) downloaded 0 time(s).
Joined: 12/27/2012(UTC) Posts: 5,475  Location: Belgium Thanks: 313 times Was thanked: 1013 time(s) in 832 post(s)
Have you checked the vmix video tutorials? Also maybe have that text on the same layer your animating
yes i check vMix tuto
but my problem the lower third is not make on CG its a video with alpha ( sequence image)
so i dont have a all anim track
Guess one wil have to animate the text synchronized with the image sequence
i found a solution (but its not very good) i dont use all the sequence of the lower third.... i use only when coming i put the name and overlay go out out.. i dont have all the 8s of my lower third.
Originally Posted by: davidcl  i found a solution (but its not very good) i dont use all the sequence of the lower third.... i use only when coming i put the name and overlay go out out.. i dont have all the 8s of my lower third. ?https://translate.google.com/
In fact I found a solution but which is not what I want. I cut my file in half (sequential) so that I only have the appearance. and I make my 2 names appear. and then in OVERLAY / duration / 6s so that it disappears on its own.
My wish would have been that all the sequence that I received from elsewhere (Lower third) is visible with the names that disappear ..
Originally Posted by: davidcl  In fact I found a solution but which is not what I want. I cut my file in half (sequential) so that I only have the appearance. and I make my 2 names appear. and then in OVERLAY / duration / 6s so that it disappears on its own.
My wish would have been that all the sequence that I received from elsewhere (Lower third) is visible with the names that disappear .. you will need to synchronize the animations of the text with the animation of the image sequence be it for coming in and coming out (TransitionIn and transition out ) do you have the files available ?
i dont know why the .RAR less 5M dont want to upload here?
GT
