obcocav
#1 Posted : Monday, September 27, 2021 1:49:43 AM(UTC)
obcocav
Is it possible to call a http request as part of a vMix script?
I have one script that uses:
Dim client = WebRequest.create("http://192.168.200.192:8888/press/bank/13/11")
Dim response = client.GetResponse()
This syntax does not work as part of another script though. Only standalone.
Any ideas?
Thank you!
#2 Posted : Monday, September 27, 2021 2:14:54 AM(UTC)
What do you mean ?
obcocav
#3 Posted : Monday, September 27, 2021 2:19:30 AM(UTC)
obcocav
As the only thing in a standalone vmix script works.
If I try those lines as part of other functions in a new script it does not. For instance:
Funtion=SetTitlePreset&Value=0&Input=33
Sleep 5000
That new script does not work.
#4 Posted : Monday, September 27, 2021 2:39:23 AM(UTC)
Sleep 5000
Not a good idea to mix and match protocols
https://forums.vmix.com/...ng-for-Dummies#post70833
btw where did you get the SetTitlePreset function from ?
Code:
API.Function("SetText",Input:="Title 43- Circling Green.gtzip",SelectedName:= "Description.Text",Value:= "Hallo")
dim client as WebRequest= WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 43- Circling Green.gtzip&SelectedName=Headline.Text&Value=other Text")
dim response As WebResponse  = client.GetResponse()
response.Close
obcocav
#5 Posted : Monday, September 27, 2021 9:52:18 AM(UTC)
obcocav
@doggy.
I used it from the Shortcut reference list. Works well.
As far as what I'm trying to accomplish. Maybe I wasn't clear. Sorry. I am trying to press a Companion button externally from inside of a vMix Script. So I need to use vMix functions then as part of that script call to a http address of an external program.
Thanks,
Kevin
#6 Posted : Monday, September 27, 2021 2:47:34 PM(UTC)
@doggy.
Thanks,
Kevin
Code is a working example of a vmix function AND a Httprequest within the same script. adapt to your needs
I do not find the SetTitlePreset function/shortcut in vMix
obcocav
#7 Posted : Tuesday, September 28, 2021 9:44:56 AM(UTC)
obcocav
Got it! Thank you!
As to the SelectTitlePreset...Here you go.
Screen Shot 2021-09-27 at 6.42.24 PM.png (461kb) downloaded 4 time(s).
obcocav
#8 Posted : Tuesday, September 28, 2021 10:45:40 AM(UTC)
obcocav
@doggy.
So I got that working fine. Next issue. Can I have more than one request inside of each script? Im an amateur at this more advanced stuff but was getting a "client already exists" error in the script. I changed the name to add a number and it saved ok without errors but only the first request runs. What am I doing wrong?
Heres what I have:
API.Function("SelectTitlePreset",Input:="MESSAGE TO MONITOR", Value:= 3)
Sleep (500)
dim client as WebRequest= WebRequest.Create("http://192.168.200.192:8888/press/bank/20/23")
response.Close
Sleep (100)
dim client2 as WebRequest= WebRequest.Create("http://192.168.200.192:8888/press/bank/13/5")
dim response2 As WebResponse = client2.GetResponse()
response.Close
Sleep (500)
API.Function("StartCountdown",Input:="MESSAGE TO MONITOR")
Sleep (310000)
dim client3 as WebRequest= WebRequest.Create("http://192.168.200.192:8888/press/bank/13/2")
dim response3 As WebResponse = client3.GetResponse()
response.Close
API.Function("SelectTitlePreset",Input:="MESSAGE TO MONITOR", Value:= 0)
Sleep (500)
Peter1000
#9 Posted : Tuesday, September 28, 2021 4:55:08 PM(UTC)
Peter1000
Switzerland
Was thanked: 88 time(s) in 68 post(s)
if you want to send several commandos in a row, you only have to define the variables client and response once.
in your code you have renamed the variable response to response2, but you close the previous connection response.
Code:
dim response as system.net.webresponse
dim client as system.net.webrequest
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=Some Text")
response.Close
sleep (1000)
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=other text")
response.Close
sleep (1000)
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=213245546")
response.Close
sleep (1000)
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=end")
response.Close
thanks 1 user thanked Peter1000 for this useful post.
doggy on 9/28/2021(UTC)
#10 Posted : Tuesday, September 28, 2021 4:56:16 PM(UTC)
Yup which is NOT the same as SetTitlePreset ;-)
obcocav
#11 Posted : Thursday, September 30, 2021 3:45:36 AM(UTC)
obcocav
My bad! That was a mistype from the beginning. BTW the script I posted did work as listed after a restart of vmix. Strange. Thanks for your help!!
Sleep (500)
response.Close
Sleep (100)
response.Close
Sleep (500)
Sleep (310000)
response.Close
Sleep (500)
