Http Request inside of vMix Script
Joined: 7/18/2020(UTC) Posts: 18  Location: MS Was thanked: 1 time(s) in 1 post(s)
Is it possible to call a http request as part of a vMix script?
I have one script that uses:
Dim client = WebRequest.create("http://192.168.200.192:8888/press/bank/13/11") Dim response = client.GetResponse()
This syntax does not work as part of another script though. Only standalone.
Any ideas?
Thank you!
What do you mean ?
As the only thing in a standalone vmix script works.
If I try those lines as part of other functions in a new script it does not. For instance:
Funtion=SetTitlePreset&Value=0&Input=33 Sleep 5000
That new script does not work.
Originally Posted by: obcocav  Dim client = WebRequest.create("http://192.168.200.192:8888/press/bank/13/11") Dim response = client.GetResponse()
That new script does not work. Not a good idea to mix and match protocols https://forums.vmix.com/...ng-for-Dummies#post70833btw where did you get the SetTitlePreset function from ? Code:API.Function("SetText",Input:="Title 43- Circling Green.gtzip",SelectedName:= "Description.Text",Value:= "Hallo")
dim client as WebRequest= WebRequest.Create("http://127.0.0.1:8088/api/?Function=SetText&Input=Title 43- Circling Green.gtzip&SelectedName=Headline.Text&Value=other Text")
dim response As WebResponse = client.GetResponse()
response.Close
@doggy.
I used it from the Shortcut reference list. Works well.
As far as what I'm trying to accomplish. Maybe I wasn't clear. Sorry. I am trying to press a Companion button externally from inside of a vMix Script. So I need to use vMix functions then as part of that script call to a http address of an external program.
Thanks, Kevin
Thanks, Kevin Code is a working example of a vmix function AND a Httprequest within the same script. adapt to your needs I do not find the SetTitlePreset function/shortcut in vMix
Got it! Thank you! As to the SelectTitlePreset...Here you go.  Screen Shot 2021-09-27 at 6.42.24 PM.png (461kb) downloaded 4 time(s).
@doggy.
So I got that working fine. Next issue. Can I have more than one request inside of each script? Im an amateur at this more advanced stuff but was getting a "client already exists" error in the script. I changed the name to add a number and it saved ok without errors but only the first request runs. What am I doing wrong?
Heres what I have:
API.Function("SelectTitlePreset",Input:="MESSAGE TO MONITOR", Value:= 3) Sleep (500) dim client as WebRequest= WebRequest.Create("http://192.168.200.192:8888/press/bank/20/23") dim response As WebResponse = client.GetResponse() response.Close Sleep (100) dim client2 as WebRequest= WebRequest.Create("http://192.168.200.192:8888/press/bank/13/5") dim response2 As WebResponse = client2.GetResponse() response.Close Sleep (500) API.Function("StartCountdown",Input:="MESSAGE TO MONITOR") Sleep (310000) dim client3 as WebRequest= WebRequest.Create("http://192.168.200.192:8888/press/bank/13/2") dim response3 As WebResponse = client3.GetResponse() response.Close API.Function("SelectTitlePreset",Input:="MESSAGE TO MONITOR", Value:= 0) Sleep (500)
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
if you want to send several commandos in a row, you only have to define the variables client and response once. in your code you have renamed the variable response to response2, but you close the previous connection response. Code:dim response as system.net.webresponse
dim client as system.net.webrequest
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=Some Text")
response.Close
sleep (1000)
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=other text")
response.Close
sleep (1000)
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=213245546")
response.Close
sleep (1000)
client = WebRequest.Create("http://localhost:8088/api/?Function=SetText&Input=1&SelectedIndex=0&Value=end")
response.Close
 1 user thanked Peter1000 for this useful post.
Yup which is NOT the same as SetTitlePreset ;-)
My bad! That was a mistype from the beginning. BTW the script I posted did work as listed after a restart of vmix. Strange. Thanks for your help!!
