Joined: 5/21/2020(UTC) Posts: 1  Location: Adelaide Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
 1 user thanked DaveBHBC for this useful post.
Joined: 4/6/2016(UTC) Posts: 84  Location: Sweden Thanks: 25 times Was thanked: 18 time(s) in 13 post(s)
Originally Posted by: DWAM  ... An easy solution for Martin to let advanced users deal with their own encoding settings could be to add the ability for the encoder (FFMPEG) to use a custom file with parameters. This way there's no need to add a custom field in the GUI which can be confusing for beginners and still let us easily tweak and optimize settings to our needs/desires (under our responsability)...
IF a user's custom file exists FFMPEG uses it ELSE FFMPEG uses settings defined via the GUI END IF +1 With the option of having an option file for streaming and another for recording.
 1 user thanked Amokka for this useful post.
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
+1, this can be a really usefull option for us...
Joined: 3/28/2016(UTC) Posts: 168   Location: SACRAMENTO Thanks: 6 times Was thanked: 27 time(s) in 22 post(s)
+1
A custom config for stream, record and multicoder. Even though i understand why DWAM proposed the custom file with no config as it would be a behind the scenes update not confusing or requiring GUI work i feel as long as its under the Advanced checkbox or if its under a advanced tab on the format window would keep to his design model and look. but by all means if we can get it sooner as just a file behind the scn4es i'm all game! Make it happen. The mob has spoken :)
Joined: 10/14/2020(UTC) Posts: 12  Location: Toronto Thanks: 8 times
Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
You have been a member since:: 7/2/2020(UTC) Posts: 7  Location: Forest Lake Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Thanks: 4 times Was thanked: 4 time(s) in 3 post(s)
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
Joined: 1/14/2021(UTC) Posts: 10  Location: Chicago Was thanked: 1 time(s) in 1 post(s)
Joined: 5/30/2020(UTC) Posts: 7  Location: Rugby Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
+1
well - is this being heard? Controlling NVenc in Streaming would be a great help, with one way or the other.
I don't really want to fuss around with external solutions.. Would be great to hear from Vmix guys if and why this poses a problem as this thread is kind of antique.
