Single Shortcut to Perform Mutliple Actions in Series?
Joined: 9/22/2021(UTC) Posts: 5  Location: Texas Thanks: 1 times
Hello, all. I am new to vMix and just started messing around with shortcuts. If this has been answered elsewhere, please post a link to the topic (as I was not able to find any info with a search). Basically, I would like a single shortcut that accomplishes this:
• Mute all mic/caller audio • Play a pre-selected video file from my local computer • At end of previous video file (can be based on length of file or an amount of time I choose, whichever is possible) end live stream
Can this be done? If so, please provide some advice on how I can implement this.
Thank you for any help!
sure, multiple shortcut functions can be put under the same key a trigger ( or a delay) can tell to stop the stream
Alternatively one could put all the functions in a script and call this script with a single shortcut
Originally Posted by: doggy  sure, multiple shortcut functions can be put under the same key a trigger ( or a delay) can tell to stop the stream
Awesome. I'll look into the options you mentioned. Thank you.
