thegrindlab
#1 Posted : Wednesday, September 22, 2021 12:17:30 AM(UTC)
thegrindlab
Hello, all. I am new to vMix and just started messing around with shortcuts. If this has been answered elsewhere, please post a link to the topic (as I was not able to find any info with a search). Basically, I would like a single shortcut that accomplishes this:
• Mute all mic/caller audio
• Play a pre-selected video file from my local computer
• At end of previous video file (can be based on length of file or an amount of time I choose, whichever is possible) end live stream
Can this be done? If so, please provide some advice on how I can implement this.
Thank you for any help!
#2 Posted : Wednesday, September 22, 2021 3:46:55 AM(UTC)
sure, multiple shortcut functions can be put under the same key
a trigger ( or a delay) can tell to stop the stream
Alternatively one could put all the functions in a script and call this script with a single shortcut
thegrindlab on 9/22/2021(UTC)
thegrindlab
#3 Posted : Wednesday, September 22, 2021 5:24:11 AM(UTC)
thegrindlab
Awesome. I'll look into the options you mentioned. Thank you.
