Shortcut for Output Audio Source ?
Joined: 4/17/2020(UTC) Posts: 50  Location: Washington DC Thanks: 6 times Was thanked: 4 time(s) in 2 post(s)
I am trying to write a script for talkback and have this working for vmixcall BUT, I also am sending audio out to callers on a NDI based system. I am feeding the NDI via Bus A just like vmixcall but I need to switch the Output 4 to Mixbus B for talkback. This would work very much like using the VideoCallAudioSource shortcut for vmixcall.
I see the SetOutput4 shortcut but it only appears to change the video source not the audio separately.
I have not discovered the secret shortcut or is does one not exist ?
Any suggestions ??
Lee
Joined: 7/4/2021(UTC) Posts: 408  Thanks: 9 times Was thanked: 60 time(s) in 51 post(s)
There's a setting that will let you route all of your audio outputs to NDI--I assume that will let you make the adjustments you want to make in your other system.
That said, I'm also having trouble envisioning what you're trying to do & why. Is there a particular reason you can't use a single bus consistently and just change which inputs are on it? I would assume that the presumption that people can/will do that is why the setting you're looking for doesn't seem to exist.
