LeeL
#1 Posted : Sunday, August 29, 2021 2:31:07 PM(UTC)
LeeL
I am trying to write a script for talkback and have this working for vmixcall BUT, I also am sending audio out to callers on a NDI based system. I am feeding the NDI via Bus A just like vmixcall but I need to switch the Output 4 to Mixbus B for talkback. This would work very much like using the VideoCallAudioSource shortcut for vmixcall.
I see the SetOutput4 shortcut but it only appears to change the video source not the audio separately.
I have not discovered the secret shortcut or is does one not exist ?
Any suggestions ??
Lee
WaltG12
#2 Posted : Tuesday, September 14, 2021 4:32:05 PM(UTC)
WaltG12
Was thanked: 59 time(s) in 50 post(s)
There's a setting that will let you route all of your audio outputs to NDI--I assume that will let you make the adjustments you want to make in your other system.
That said, I'm also having trouble envisioning what you're trying to do & why. Is there a particular reason you can't use a single bus consistently and just change which inputs are on it? I would assume that the presumption that people can/will do that is why the setting you're looking for doesn't seem to exist.
